I just want to print this shower curtain ring:
For some reason SuperSlicer doens't like the circles and after slicing the model looks like this in preview.enter image description here
What is the issue with the slicer? Is there any setting that I might have and ruin the model?
Thanks
    $\begingroup$ Using the link, I downloaded the single ring and Meshmixer says there are no flaws in the model. PrusaSlicer also slices the file without complications. Have you tried another slicer in order to have additional data? $\endgroup$
    – fred_dot_u
    Commented Sep 5, 2023 at 16:05
  • $\begingroup$ @fred_dot_u I removed the preset that I originally had and reimport it and everything is fine now. Possible that the config got corrupted $\endgroup$
    – Wolffyx
    Commented Sep 5, 2023 at 16:37
    $\begingroup$ Good deal. Consider to create an answer to your own question, give it a day and mark it correct with the check mark. $\endgroup$
    – fred_dot_u
    Commented Sep 5, 2023 at 17:00
At the moment I didn't find the exactly what option from config did this but after reimporting the preset everything is back to normal(possible something got corrupted in the preset or the app, I don't know for sure). I will still research to see what caused the issue for feature. Thanks all
