I bought the BambuLab X1-Carbon without considering where to put it, and now I realize there are only two options:
- My small studio room where I also work.
- The utility closet, which houses my washer/dryer.
Studio Room: The issue here is that I spend a lot of time in this space. While I’m only planning to print with PLA and PETG (both considered relatively safe), the poor ventilation and long hours spent in the room still concern me. I’ve thought about converting part of my bookcase into an airtight enclosure with carbon and HEPA filters to house the printer, but I’m questioning if it’s worth the effort—especially because I'd have to also buy expensive PM sensors to validate it.
Utility Closet: The main drawback here is the humidity, which ranges from 50-70% (60% average). I can’t find clear information on whether this level would damage my filament, even with the AMS silica bead containers mod. However, the closet is where the ventilation system is so the room has negative pressure and vents to the outside.
If the utility closet works despite the humidity, I’d be inclined to use it. Online sources suggest the printer doesn’t produce harmful compounds, but I’m still uneasy about spending 8 hours in the same unventilated room as the printer; opening the window isn’t ideal due to the cold.
Thoughts? Should I go for the utility closet if the humidity isn’t a dealbreaker? How feasible is it to build an airtight fully filtered enclosure out of normal materials?
