9
I have a new BLTouch that is setup (using Marlin 1.8.7) but I want to increase the probing grid from a 3x3 to something like a 5x5. I am using bilinear leveling with a 3x3 grid.
How would I go about changing that?
12
You need to change the constant value(s) in your Configuration.h file of your Marlin version from:
// Set the number of grid points per dimension.
  #define GRID_MAX_POINTS_X 3
  #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
to:
  #define GRID_MAX_POINTS_X 5
This shows that to go from a 3x3 grid to a 5x5 grid you only need to change one value. Do note that you can set GRID_MAX_POINTS_Y to any value other than GRID_MAX_POINTS_X; replacing GRID_MAX_POINTS_X in the line with GRID_MAX_POINTS_Y to 4 would yield a 5x4 probe grid:
  #define GRID_MAX_POINTS_Y 4
  • $\begingroup$ "You need to change the constant value(s) in your Configuration.h file of your Marlin version" And, how does one do that? $\endgroup$ May 26, 2021 at 18:38
  • $\begingroup$ @WeldonThomson Download the firmware, get or configure it for your printer, compile the software and install this onto the printer controller board. $\endgroup$
    May 27, 2021 at 6:31
