Background:
I have an Alfawise U20 (CR10 clone) and am still somewhat of a noob, though I've been learning as much as quickly as time will allow.
The Alfawise U20 has "out-of-filament" detection, though I'm not 100 % certain how it works. I think that there's a roller across from the toothed knob that drives the filament into the Bowden tube, and if the roller doesn't roll, that means the filament has run out(?).
Alfawise U20 extruder and filament run-out sensor
I've become fairly proficient printing with PLA but this is the first time I've tried printing with PETG.
Problem:
Almost immediately after starting a print, the printer pauses the print and displays message "Out of filament. Would you like to change filament?" There's not even time for the toothed knob to click, which I've seen when trying to print PLA too fast/too cold.
If I manually extrude some filament, it seems to work fine. When I resume the print, it will print for anywhere between ~2 seconds & ~5 minutes before pausing again, prompting me to change filament.
I'm printing at 240 °C. I've seen opinions vary pretty far & wide wrt how hot to print PETG, with some people saying you can print successfully as cold as 215 °C, and others saying you should crank it up to 250+ °C. This filament is rated for 230-250 °C extrusion.
Again, manually extruding filament works fine. No slippage, no clicking. Smooth extrusion.
I've read that PETG is extremely hygroscopic. Could my problem be caused by the filament having absorbed too much water? How would I even determine if this was the cause?
What else could be causing my problem? I've read some printers' "out of filament" detection have problems with translucent filaments?
11
    $\begingroup$ Welcome to 3dPrinting.SE! $\endgroup$ Jul 8, 2019 at 21:33
    $\begingroup$ Is your filament translucent? If so I suspect that's your problem. My understanding is that most "out of filament" detectors are optical. $\endgroup$ Jul 9, 2019 at 3:20
    $\begingroup$ @R.. That was my first guess also. W.r.t. being gyroscopic, my largest printer is located in our laundry room, where laundry dries, I have my 2.2 kg PETG spools uncovered, no problem whatsoever. $\endgroup$
    Jul 9, 2019 at 8:20
    $\begingroup$ What kind of filament sensor do you have? Is it optic or mechanical? Please share a photo. $\endgroup$
    Jul 9, 2019 at 9:25
    $\begingroup$ Online reviews indicate that many of the firmware updates cause new bugs. I dunno whether your version generates spurious 'out of filament' notifications, but if you can find a forum page or two dedicated to this model, that might be the best place to ask. $\endgroup$ Jul 9, 2019 at 14:46
Shoutout to @0scar for posting a photo of the filament sensor, that was super helpful. Also thanks to everyone else who pointed me to the filament sensor and resources around that.
I also tracked down this review which had great information around my printer's filament sensor as well. It turns out that the hole that goes to the sensor is way too big and there's a lot of play with the filament. As I jiggled the filament up & down I could hear the sensor clicking on & off, clearly indicating that if the angle of entry of the filament was too low, the sensor would not be depressed and this would continue to be a problem.
So for my next print, I did what that reviewer suggested and simply unscrewed the sensor & taped it so it would not stop my print. My print was unsuccessful for other reasons (under-extrusion/failed to adhere to the build plate 😫), but at least I think I've figured out what's going on with my filament sensor. Thanks again everyone!
    $\begingroup$ the clicking tells us it's mechanical $\endgroup$
    Jul 11, 2019 at 6:19
  • $\begingroup$ Yes I agree, it's a mechanical filament sensor, not optical $\endgroup$
    – steve
    Jul 13, 2019 at 1:08
