I've got a Prusa i3 MK3. I have printed with PLA, PETG and tried HIPS. Haven't had any clogs with PLA and PETG, but with HIPS I've got a weird problem.
My first three test prints in HIPS went fine, but then I got a very bad clog (required total disassembly of the extruder) twice. And every time, it was at the same moment during a print. The object I was printing was a hollow cylinder. The walls were about 5 mm thick, getting thinner near the top edge. At the moment the walls started getting thinner, the problems started.
I've read that HIPS can clog if the filament moves too slow through the hotend. At the moment the clog occurred, the printer was printing a very narrow part, and the extruder had to move around a lot. Is it possible that, at that moment, the filament moves too slow and the problems starts? I have also printed two copies of the object in a single run, and then the problem didn't occur.
I hope my explanation makes sense, but here's what it comes down to: Does HIPS clog easily when the filament moves too slow, and if it does, what can I do to solve this?
