It has been a long journey failing and printing over and over to be able to print at faster speeds. All I did mostly was trial and error. I am currently trying to wrap my head around a problem that has been asked by user:1998 (mhelvens): Can we manage to make a uniform formula for printing very fast with high temperatures? (Increasing hotend temperature to compensate for increased filament throughput)
Using Ender 3, Hero Me Gen5 with E3D V6 volcano, mdd kit 1.2, Klipper firmware
When I start printing at 215 °C (recommended temperature for my filament) everything is alright, because of initial layer speed...
When I come to 100 mm/s the print clearly fails, the plastic doesn't stick, it even swirls up and is just too solid and then it damages the nozzle when it bumps in to it...
If I start at high temperature, the print is failing at the start and then doing ok, which is equally as bad
When I have high temperature and high speed the print wont stick at the beginning...
The solution in my opinion is to gradually increase speed with temperature, adding that as a function of the firmware. Also probably involving filament flow % and pressure_advance...
Is there a formula for what I'm asking?
Can we implement it in the software or does this have to be done through trial and error all the goddamn time?
