A print that is paused with an M0
can be unpaused with M108
That works with my Chiron running Marlin 2.0.7.2.
However, it also has a display that uses its' own serial protocol to communicate with Marlin. I want that display to be able to unpause my printer when it has encountered M0
in the G-code.
I tried injectCommands_P(PSTR("M108\n"));
in the code, but it did not work. Perhaps I should not have a new-line at the end of it.
What is the correct command to do this?
void GcodeSuite::M108() {
TERN_(HAS_RESUME_CONTINUE, wait_for_user = false);
wait_for_heatup = false;
Above is the Marlin code for M108
. Would be great if someone could decipher what TERN means.
