I've done a few prints on my MakerBot Replicator+ now and I'm curious if anyone else knows what the typical lifespan is signs of degradation are for the grip surface tape?
I'm used to using Kapton tape in the past. Which will bubble, scratch, and even tear at times, indicating that the tape should be replaced. However, this new MakerBot "Grip Tape" is a very stiff, precut material, with extruded plastic anchors to help evenly spread the tape and keep it secure on the build platform. The tape also has texturing on the top face that helps with adhesion.
So, this new tape seems somewhat impervious to bubbling, scratches, and tears. I'm curious what signs I can look out for that indicate that this new grip tape needs to be replaced.
Obviously the tape isn't a permanent solution, so what are some signs that the tape should be replaced?
