I just made my anet a2, and when I hit auto-home it goes off the board makes a loud clacking sound going down a bit (under the heat bed but off to the side). Any suggestions?
1 Answer
Your limit switches are not working properly - they should always hit.
Do the following steps:
- Move axis in all possible directions, both positive and negative;
- Check limit switch wiring;
- Limit switch output.
