I hit this issue again in January 2019 with CuraEngine 3.6+git. Since support for multiple extruders was added, it now auto-loads a per-extruder settings file that overrides the main settings file and the command line, so -s material_diameter=1.75
on the command line did not help. Given $foo.def.json
, it seems to construct the filename %$foo_extruder_0.def.json
, and if that does not exist, loads fdmextruder.def.json
, which sets material_width
to a default of 2.85
I was able to solve the problem by either patching fdmextruder.def.json
, or making a copy of it named to match my printer's settings file, with the 2.85
changed to 1.75
Update: There should already be extruder files for supported printers, but they're in a different directory, so they won't be found when invoking CuraEngine
from the command line unless you've set the CURA_ENGINE_SEARCH_PATH
environment variable to include the path they're in. Alternatively you can copy them to the same directory as the main printer json files.
