I got myself an Ender 3 printer, put it together and tried the test g-code, worked fine. But i sometimes have problems with under extrusion, as shown in the picture below.
Under extrusion visible to the left while the part to the right is fine
As you can see, the part to the left is almost not printed, but the part to the right is fine. These "holes" are a lot of places, and i dont understand what is causing a temporary clog or whatever the problem may be.
Anyone know something about this problem?
  • $\begingroup$ Have you run this gcode multiple times, and do you get the same underextrusion in the same location every time? If not, it could be just a temporary filament advancement issue. $\endgroup$
    – Davo
    Commented Jan 24, 2019 at 14:00
  • $\begingroup$ I can confirm it does not happen in the same places every time the same g-code is run. But it is happening every time I print something, so where would I start trying to diagnose it? $\endgroup$
    – Fiskelord
    Commented Jan 24, 2019 at 14:22
  • $\begingroup$ Also, extrusion seems uneven, starting pretty good and getting bad pretty quick $\endgroup$
    – Fiskelord
    Commented Jan 24, 2019 at 14:24
  • $\begingroup$ Does your spool unroll freely? You specifically mention Slic3r, so does this imply that it does not happen with Ultimaker Cura for instance? $\endgroup$
    Commented Jan 24, 2019 at 14:53
  • $\begingroup$ I tried lubricating the spool holder, but it didn't help, so I believe it moves as it should. I tried cura as the first slicer, but for some reason it just fucks up completely on my ender 3, probably don't have it set up correctly. I have gotten a few decent prints from Slic3r, but the issue remains. $\endgroup$
    – Fiskelord
    Commented Jan 24, 2019 at 17:38
What you experience is temporary under-extrusion. This could be a typical result of friction in the supply of filament to the extruder. I've run into this also a week ago when the shaft of the spool holder caught a plastic bag next to it which wrapped around the shaft creating a lot of friction. Friction can also be caused by filament that gets entangled on the spool, this is usually a problem if the spool unrolls too freely on the holder (too less friction);it unrolls a few windings, and then tightens those entangling the filament. Also, if you use 2.85 mm filament on small diameter spools, the last stretch of filament has the smallest curvature and as such requires the most force to pull it to the extruder (this can go in steps).
Furthermore, slipping of the extruder gear is also a (rare) possibility (when using a stepper directly to drive the extruder gear, a flat spot on the stepper shaft should prevent this).
Be sure to inspect the filament release from spool to extruder and try to see (and listen!) what happens when you print a part when you experience the under-extrusion.
