I followed this tutorial on how to set up BLTOUCH v3.0 with my Ender 3 Pro. (v1.1.4 motherboard)
I even removed C7 capacitor on Z axes. And no luck. My BLTouch probe is working, it turns on with the Ender and testing is fine. But it doesn't stop the printer on Z axis while auto homing.
Firmware is from firmware.th3dstudio.com
Any ideas? Any advice is highly appreciated.
My configuration.h file: https://paste.ofcode.org/Z4kKiGwYXC6yQ698t9uaeY
My configuration_backend.h file: https://paste.ofcode.org/34tuX4mG3Ph57jSnT8YByi3
  • $\begingroup$ I'm no personal fan (although many other people swear by it) of all those Marlin derivative firmware solutions that try to encapsulate all the printer configurations. These lag behind the original sources and maintaining them and keeping it to work properly for all printers is quite a challenge. If I were you I would use the original Marlin sources and work from there. $\endgroup$
    Commented Apr 1, 2020 at 8:54
If the probe works, but not on auto homing, it could be that the Z endstop/probe wires are incorrectly wired.
From "The complete BLTouch/3DTouch guide for Creality printers (CR-10/s,Ender 2,Ender 3) for Auto Bed Leveling UPDATED" can be read:
If you connect your bltouch and when auto homing the sensor doesn’t register & the z axis keeps dropping pressing into your bed, turn your printer off, disconnect the power and invert the black and white connectors in the z limit switch header (put black where white was, put white where black was).
This can also be found in this Marlin issue tracker:
The Problem was the polarity of the sensor wires was reversed.
If reversing the polarity does not work, move to the original Marlin firmware.
    $\begingroup$ Thanks, the real problem was bad wires. Not the wiring, but wires. I just put new ones and everything works fine! $\endgroup$
    – Mr.Code
    Commented Apr 4, 2020 at 11:20
