I've just received my Ender 3v2 and tried multiple SD cards, all have been formatted to FAT32 with no luck. Under the Print selection, all I get is the back button. I looked and I have the V4.2.2 and the firmware is up to date, Showing 1.0.2 unless this is not right and this is why I'm having this issue. Even when plugging directly into the computer, nothing is showing up.
1$\begingroup$ Format them as FAT16. How big is the card? $\endgroup$– user77232Mar 31, 2021 at 14:13
1$\begingroup$ Pretty sure FAT32 works fine. Only exfat or whatever latest junk MS is pushing is a problem. This sounds more like a hardware problem. $\endgroup$– R.. GitHub STOP HELPING ICEMar 31, 2021 at 15:06
$\begingroup$ We assume your SD card matches the reader as far as HD, xD, etc. SD cards that are too large can be a problem. $\endgroup$– Perry WebbMar 31, 2021 at 16:43
1$\begingroup$ 1.0.2 is Creality's unique version/branch of Marlin that they've created. It's a branch of Marlin 2.0 so that is totally fine and compatible with a 4.2.2 board. If you've ruled out cards, it may well be the reader. Can you use something like this to test if you can load files from SD cards using the USB port instead of the reader? $\endgroup$– RykaraMar 31, 2021 at 17:47
$\begingroup$ The most recent card is 16gb but I also tried 8gb. And it is a miroSDHC I have not tried using anything to read through the usb port. I'll try that as soon as I can. I'm hoping it's not a hardware problem. $\endgroup$– Diabetic MaxApr 1, 2021 at 1:20
What helps for me is re-inserting the TF card several times. Indeed, the machine has some trouble reading it, strange because this would seem to be an easy problem compared to the overall design of the printer....
I have the same issue but whilst none of these worked for me they have worked for other people:
- Make sure the name of the G-code file begins with a letter or number
- Make sure the G-code is not in a subfolder
- Make sure the name of the G-code file is less than or equal to 8 characters long
After I attempted all of these, reinserting the SD card multiple times worked but I don't know what fixed it or if it was just I had been putting it in wrong though I didn't try anything different.
Just to be sure - you know that the SD Card reader in an Ender 3 is upside down? That means the visible contacts on the micro-SD card have to be facing upward.
If someone has forced a card in the wrong-way around, it could have damaged the reader.
Personally, once I got OctoPrint working I never print from microSD card at all. Not a solution but a workaround.
1$\begingroup$ Oddly, the original version had it right, then for some reason they swapped the orientation of the electronics box on later units. $\endgroup$ Jan 1 at 17:38
1$\begingroup$ It was to get the slot away from the table and thus better accessible. This mandated putting all tall components on the one side and flipping the board to be mounted on the ceiling - the tall components facing down. This also simplifies access to the board, no longer you need to remove the top lid awkwardly but access all from below $\endgroup$– TrishJan 3 at 11:07
