I got an Anet A8 for Christmas.
I am trying to print a calibration tower and the z axis stops lifting at approximately 100mm.
I checked that the gantry is able to travel along the full length of the threaded rods, and while resetting the bed height I noticed that the LCD display showed the extruder height above the bed. It reads 0 at home (good) but goes back to zero when I manually turn the rods so that the gantry goes above the heigh at which the print stopped.
Any thoughts on what to check? I am double checking all the mechanical bits (connection to stepper coupling, ease of turning, etc...).
My slicer is Cura 3.1.
  • $\begingroup$ Can you move higher in Z via the "position - Z-axis" menu on the printer? DId you make sure that the current z-limits for the printer volume in Cura are set correctly? $\endgroup$ Jan 9, 2018 at 15:06
  • $\begingroup$ @CarlWitthoft - Cura won't produce any Gcode if the model doesn't fit entirely in the print volume, so I don't think that should be the cause. $\endgroup$
    – mac
    Jan 9, 2018 at 21:50
I found two issues:
  • While cutting the cables to size, I made the cable for the z-axis too short.
  • In Cura the y height reset to 100mm rather than the 240mm I had earlier specified. I assume the G-code I used was sliced with the wrong settings.
